Have got one of these booked in on Monday, apparently powers up but goes straight to error, has anybody looked at these before. Never repaired one myself
Cheers
Andy
These were prone to this fault. If it comes back then loosen the interlock screws, push the lock as far as you can towards the door and tightened the screws as tight as you can. It only moves about 1-2mm but stops this fault.
bazza500 wrote:These were prone to this fault. If it comes back then loosen the interlock screws, push the lock as far as you can towards the door and tightened the screws as tight as you can. It only moves about 1-2mm but stops this fault.
