Panasonic NA14VA1
  • #65031
    pmb
    Washing Machine NA14VA1
    Need a new Door Gasket,Connect and Masterpart dont have it.
    A panasonic Site gives a phone number for spares which turns out to be for Service calls only.
    Old gasket had come off, Tryed to get old gasket to stay in place, while putting band on, but gasket very loose hopping new gasket will be tight,and not fall off.
    Am thinking how I can modify a tool to slide band on.
    #358955
    bazza500
    Panasonic NA14VA1
    The new gasket will be as loose as the old one. They are a nit of a pain but persevere and you will get there
    #358956
    pmb
    Re: Panasonic NA14VA1
    Thanks but their is a small tear, Not sure if it was caused by
    spring or not, I can repair it with silicon.
    #358957
    pmb
    found a easy way to fit.Remove weight above gasket,
    Band has loops just before spring, put plastic tie through loops
    tighten until closes up and clip together.
