Panasonic U11 message on NA-140ZS1
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Panasonic U11 message on NA-140ZS1
Viewing 15 posts - 1 through 15 (of 15 total)
  • #97849
    playnice
    Hi, I have a Panasonic Washing Machine Model no. NA-140ZS1 and I am receiving an Error U11 which is something to do with draining the water. I have checked all hoses and even sat next it during a short cycle wash with a bucket next to me and I’m not seeing an issue. Please advise. Thanks.
    Hopefully I won’t need to cut my losses as it’s been pretty good until now.
    Cheers,
    playnice
    #469797
    but does the machine drain the water at a reaonable rate ?
    playnice
    Thanks for the reply electrofix – I can’t remember now – I’ll try it again on the quick wash – anything else I should check do when I do it.
    #469799
    not at the moment
    we need to know if it has a fault or just thinks it has
    just select a rinse only programme, Wait till its full then cancel the programme and select drain, then see if it drains in a reasonable time
    playnice
    Hi Electrofix, the draining speed seems okay.
    I just ran a quick wash (empty) and everything seems fine until it gets to this screen, you can hear it trying to drain. Tried to upload an image but it’s complaining about a quota issue. The screen it appears to be having issues is with ‘spinning’ yet I see no issues with the spin as I can run a spin only program and that’s fine. After a few minutes after the ‘spinning’ screen you get Error U11 unable to drain, please check hose. No issues with the waste pipe etc. So if you run it dry no issues, but if you put it on a wash program and because its taken in water we get the above 🙁
    #469801
    well from that it sounds like a pump issue. Have you taken the drin filter out and checked it? Also when you take the filter out if you look inside the housing with a torch there may be a white cross at the back. If yes this is the pump impellor, make sure nothing is stopping it. I have had 5p peices, hair clips, Elastic bands to name a few. All will stop it pumping out
    playnice
    Thanks Electrifix,
    Just checked the filter area and it is clean and the propeller freely turns.
    Though when i opened up the filter area some water did come out probably 2 maybe 3 cup fulls.
    If it is the pump how much am i looking at approx?
    #469803
    we are still not sure its a pump problem
    you said it was trying to drain but if it was only trying but not succeeded then when you opened the filter it would have all flooded out. Instead you said you got 2 or 3 cup fulls. Which means it must be pumping out
    am i correct ?
    playnice
    Yes correct, only 2/3 cup fulls came out. The rest must have went down the drain pipe as per usual and i heard as such. I’ve removed the top cover but can’t see much it appears the side panels don’t come apart either. There is however a silver panel at the back.
    #469805
    well in that case the problem may lay in the pressure switch. The pressure switch measures the water in the machine and reports this to the computer. if the air chamber at the bottom of the machine then even though the machine is empty the switch may be thinking its still full. it would mean finding this component and making sure its clear
    only seen one of these to work on so i dont know exactly where it is or how to get at it
    playnice
    Thanks electrofix, it’s a shame i can’t upload any images.I wouldn’t know what to look for.
    #469807
    if you wish to add pice you have to host them on another site and post a public link
    playnice
    I’ll try and add some tomorrow cheers again.
    #469809
    andyjawa
    Tried to find a picture of the sump hose ( tank to pump filter hose ) for your model but cannot find one as there was a common issue on SOME Panasonics that had a 2 sump hose nozzles that were under the tank. Basically if one nozzle gets blocked-up it causes a partial vacuum stopping the water being pumped away SOMETIMES. Power off, back off and see if your model has 2 nozzles under the tank and if so that is where the problem will lie- very common. Not that easy to get at and from memory I think the machines have a plastic base to add to all the problems of access……in true lack of appliance industry forethought!!
    #469810
    playnice
    Thanks guys, I haven’t had a chance to open it up again as i’ve lent out my tools to my brother. As soon as I get them back I’ll advise.
    We have a temporary washing machine that the neighbour was throwing out (good timing) outside in the garden doing its thing for now… its very noisy thus why they’ve decided to get a new one. bearings i suspect!
