Panasonic Washing Machine Help
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Panasonic Washing Machine Help
  • #77154
    ps007
    I have a Panasonic Washing machine. Over the last 2 days I received an error code U11. It seemed to be pumping out water slowly or not at all. I did a 90 degrees wash and drained the machine and everything was OK. I then started getting the U11 again and now get U14. I also have a tub load of washing stuck.
    Any help appreciated.
    #401192
    Andy jones
    Re: Panasonic Washing Machine Help
    Have you checked the filter etc?
    #401193
    ps007
    Yes I have checked the filter. There was nothing there.
    #401194
    Andy jones
    Does it connect to the sink trap. If so check there as well, sounds like a blockage somewhere
    #401195
    ps007
    It goes directly outside I have the drain hose in a bucket and no water is coming out when I set it on the drain cycle.
    #401196
    Andy jones
    I take it you can hear the pump working, if yes there’s a blockage probably in the sump hose
    #401197
    ps007
    I can her the pump working. Sometimes there is a grinding noise. It sounds like it is pumping but there is no water going through it.
    Is there any way to open the door on this machine to get the washing out and is the sump hose accessible.
    Thanks for all your help.
    #401198
    BobHope
    there is a motor that opens a valve on these washers and they always jam after a tub clean cycle, new valve required or you could just jam it open.
    bob.
    #401199
    ps007
    How do I get to the valve to jam it open.
