PARKINSON COWAN GAS COOKER RG60DLBKN
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries PARKINSON COWAN GAS COOKER RG60DLBKN
  • #52340
    funkyboogy
    oven ignition keeps sparking after oven has lit ,
    havent seen this one b4 , ant ideas
    cheers ally
    #311402
    washermanuk
    Re: PARKINSON COWAN GAS COOKER RG60DLBKN
    Hi matey yes had this fault before thinks its to do with ionization? needs the flame to complete the circuit and stop the ignition :rolls: adjusting the spark probe gap may help or a fault with the ignition probe? Found this but 2 technical for me 😯
    The problem with most prior piezoelectric ignition systems, including that of Berlincourt, has been that ionization shorts out the series spark gaps when such gaps are located too close to the burner ports. Positioning the spark gaps far enough from the burner ports to prevent shorting out due to ionization often results in erratic ignition or no ignition at all. Moreover, most, if not all, conventional systems cannot be adapted for heavier as well as lighter than air gases and are usually limited to one such category. I could be totally wrong tho 😳
    #311403
    Jazzmeister
    Probably just a faulty ignition unit matey…..The re-ignition part inside is not registering the heat! if that were to fail ht lead or igniter!
    Jazz
    #311404
    funkyboogy
    CHHERS …will order ht lead and ignition unit
    will update asp
    cheers ..
