Part 140002162232
  • #98364
    LJDomestics
    can anyone enlighten me… in the last couple of year ive changed around 5 of these elements and on 3 occasions it still dont heat, changed turbidity sensor too…still no heat, always just 1 of the stats open circuit but element itself fine, anyone else changed this particular element and found its still not heating, ive checked the pcb’s each time looking for the obvious, getting frustrated as to wtf is happening when the stat on the element is going.
    #472073
    the stats on the elements as far as i know are an overheat protection. as with all stats they both wont trip at the same temp so you will always find only one has gone.
    as for reasons, well, anything that means low water flow
    blocked filters or bars, motor problems including mechanical and blocked impellor. faulty diverter valve etc
    can easily source the manuals if you want a read but would need the pnc to find correct one
    LJDomestics
    Thanks dave… i revert… its now only 2 in the last few year, customer rang lastnight saying ( number 3 ) its heating, turns out she was expecting instant heat, i told her to wait until the dispenser opens and look again, customer eh?
