Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › PAT Test failure
- This topic has 9 replies, 7 voices, and was last updated 18 years, 10 months ago by
bobokines.
June 13, 2007 at 10:07 pm #28116
bobokines
ParticipantCan someone enlighten me on how a PAT tester works?
I have a local school that has asked me to check out a BEKO dishwasher that has failed a PAT test on “leakage current”.
The appliance is perfectly ok with any test that I can perform with a 500v Meggar.I have heard of this before but never been able to resolve the problem.
Does a PAT tester test earth leakage current at 50Hz?
Bob
June 14, 2007 at 7:07 am #216977Simon46
ParticipantRe: PAT Test failure
Has it possibly dried out now?
S.
June 14, 2007 at 1:16 pm #216978petalpop
i had a washing machine that failed a pat test but when i went out to see it it was fine till i put water in it then found element went down to earth
June 14, 2007 at 4:48 pm #216979eastlmark
ModeratorRe: PAT Test failure
bobokines wrote:Can someone enlighten me on how a PAT tester works?
Bob
The basic ones dont test earth leakage but the more advanced do. Even then it is awkward as they run the machine for a few seconds in order to test it which is fine for a kettle but makes waiting for interlocks to engage and pressing start buttons almost impossible. AFAIK earth leakage does not need to be tested as far as PAT testing is concened only insulation and earth bond. Loads of ‘our’ appliances will fail earth leakage tests if that was the case.
June 14, 2007 at 10:41 pm #216980bobokines
Thanks guys. I have tested the macihine for over 30 minutes and through a heat pause.
The company that done the PAT test are going to retest so it should be interesting.
Bob
June 15, 2007 at 8:46 am #216981dpm
ParticipantYou might want to be there to watch. Bleedin pound-a-plug numpties can be a nightmare.
June 17, 2007 at 6:32 pm #216982keithwilliams
£2.50 actually.
i where both hats as an appliance repairer and a pat tester.
don’t knock it though cos we are grossing £50k and growing fast.
i’m also a lifeboat crew member and can tell you i’ve saved a lot more lives pat testing.June 17, 2007 at 6:33 pm #216983keithwilliams
of couse that should be wear two hats. i’ll spend some of my £2.50 on a dictionary.
June 19, 2007 at 6:46 pm #216984pen0668
are u sure it didnt fail on flass test some are testing appliances with no experiance on elecrics or reading all they do is buy a pat tester and go!!
i had one failing appliances it was the suppresser on flash test if you read info you cant flash test certain appliances contact manufacture if unsure
😕June 19, 2007 at 7:00 pm #216985bobokines
Apparently this was the only appliance in the whole school that failed, so I would imagine that they are using the equipment correctly.
I think some PAT testers test a leakage current on AC rather than just reading insulation resistance at 500V DC as we do on our tests.
I haven’t heard the outcome yet but I will follow it up shortly.
Bob
