Re: Paul Bocuse Rosiers Cooker – Oven and fan issue
Easy way to test which elements are working.. turn the oven on with the door open and the shelves taken out.
after a couple of minutes quickly touch the base of the oven in the centre. If this is not getting warm but the top element is then it will need a base element.
On the R/H oven take out the roller unit which will show you the bottom element.. do the same again but don’t touch as this one gets red hot if working.
There are two types of Rosiers Fan assisted oven which is conventional with a push button to operate the fan next to the oven switch and a true fan oven which has a round element round the fan motor.
R/H is conventional .
Bryan
