Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › PCB code not working Admiral maytag F/F
- This topic has 10 replies, 3 voices, and was last updated 8 years, 9 months ago by
Kaydynk.
July 1, 2017 at 5:30 pm #91575
Kaydynk
ParticipantHelp !! Please I just bought a new pcb board for model GC2224GEKB For maytag admiral fridge freezer and my code on fridge freezer is 28 but it won’t store this code..
Any help greatly appreciatedJuly 2, 2017 at 4:24 pm #448614SAMURI
ParticipantRe: PCB code not working Admiral maytag F/F
Try the default code of 05 if this does not work then 15.
In most cases 05 works 28 would only work if you have the same jazz board number on the PCB.
Bob
July 3, 2017 at 8:14 pm #448615SAMURI
Have you tried the code yet ?
Bob
July 4, 2017 at 5:06 pm #448616Kaydynk
No I have tried these codes you advised. I got part from espares
July 4, 2017 at 5:11 pm #448617Kaydynk
Compressor doesn’t seem to kick in with the codes 05 or 15 she advised by Bob
Thanks Kay
July 4, 2017 at 6:35 pm #448618electrofix
ModeratorRe: PCB code not working Admiral maytag F/F
have you left it long enough from what I have heard some compressors don’t cut in straight away and can take some time
July 4, 2017 at 7:43 pm #448619Kaydynk
ive left it a couple of hours.
July 4, 2017 at 7:56 pm #448620SAMURI
Did it store the code ?
Bob
July 4, 2017 at 8:03 pm #448621SAMURI
Unless you manage to store a code it will not run.
If you have stored a code and the fans run but not the compressor then it may be a relay or compressor fault.
If it does not make any noise at all and the codes are stored then it may be a faulty new PCB.
Try opening the doors to see if you can here the compressor start.
Bob
July 4, 2017 at 8:14 pm #448622Kaydynk
ive left it a couple of hours on code 05 and 13. The fans are running but nothing from compressor.
Is it worth trying another new board or give it up as a loss.
Thanks for advice
KayJuly 4, 2017 at 10:50 pm #448623SAMURI
You need to get someone to check to see if you have voltage reaching the compressor.
It may just be a relay on the compressor.
If no voltage at the compressor then it may be a faulty new pcb.
Try opening the doors to see if you can hear the compressor run or check to see if the compressor is Hot.
I the compressor is hot then it is a compressor fault.
Bob
