PCB fault or something else?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum PCB fault or something else?
  • #84007
    macman35
    I have a Bosch SRS55L12GB/15 which is stopping on 1 minute on the display (or is this error code 1?). The pump continues to try and run while this happens. A little research indicates that this is usually due to a faulty heater relay on the PCB overheating and melting out the soldered connection. I took the board out yesterday to send it for testing and repair (a new PCB at £130 doesn’t seem sensible on an 11 year old machine), but there is no visible sign of overheating on the 3 relays, the board, or their connections.
    Is it still likely to be a faulty relay, or should I be looking at other components given this symptom?
    #424483
    Re: PCB fault or something else?
    Could also be a flooded base tray? Faulty heater?
    #424484
    macman35
    OK, so I should check for continuity at the heater terminals then. But what is the cause of a flooded base tray, and how do I check this please?
    #424485
    macman35 wrote:OK, so I should check for continuity at the heater terminals then.
    Yes.
    macman35 wrote:But what is the cause of a flooded base tray,
    An internal leak somewhere.
    macman35 wrote:and how do I check this please?
    Close visual inspection.
    #424486
    macman35
    Thanks. The other possible cause I have researched is a blocked pressure chamber?
    Or does this error code narrow it down specifically to a heater fault?
    #424487
    macman35 wrote:Or does this error code narrow it down specifically to a heater fault?
    It is NOT an error code by the way. Enough of the questions, time for you to get hands on and check out. You have plenty to work with to get to the bottom of the problem I would suggest. Enjoy! 😀
    #424488
    macman35
    Update: it was a fault on the PCB-the heater relay.
    Got that repaired by QER and all now working fine. Thanks to all who gave advice.
