Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › PCB for a Candy CM1166-80
- This topic has 8 replies, 3 voices, and was last updated 14 years, 10 months ago by
Enfys.
June 1, 2011 at 5:02 pm #63126
Enfys
ParticipantHi
I can see a Module for sale on the shop for Module No 41013731 and I have a Faulty 41013727
Will the one for sale work as a Replacement.
June 1, 2011 at 7:31 pm #352670helo_75
ParticipantRe: PCB for a Candy CM1166-80
neither of thise numbers are correct for your machine
the correct number you need is
09200779
do you have the first 8 digits of ur serial number to make 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure
June 1, 2011 at 7:32 pm #352671helo_75
and why do u think the module is faulty?
June 2, 2011 at 8:19 am #352672Enfys
The Module Number I gave is actually on the board, so that appears to be the correct module. I’m not at the office right now for the Serial Number, but will get back. The Machine is intermittently cutting out. I suspect the board because other parts seem to work ok and the Board has lost its proper mounting to the machine. i.e. the Plastic Backboard has snapped and its not held in its proper place.June 2, 2011 at 4:52 pm #352673helo_75
the only reason i ask, is cos that number u have technically doesnt exist, it must have been superseeded, ifu can get the serial number, i will confirm the exact one u need!
June 2, 2011 at 6:19 pm #352674Enfys
I’ve attached an Image, and you can see its on the Label, but perhaps as I’ve reduced it due to limitations here, you might not see well.
June 2, 2011 at 7:22 pm #352675kwatt
KeymasterRe: PCB for a Candy CM1166-80
That’s the input module you’re looking at in the store. It does little apart from tell the Coreboard what to do as it’s the one behind the buttons on the facia. I would very much doubt that was the cause of intermittent cutting out, in fact I’d say it was a 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} or higher chance that it isn’t.
If it’s the Coreboard, which is what that looks like, you need the version programmed specifically for the model, the numbers on the board could be any sort of factory reference that likely means little outside the factory as it usually doesn’t.
The programmed board is part number 09200779 and is a special order for just about everyone. They’re about £70 a pop plus VAT and shipping so it’s an expensive part to take a punt on.
HTH
June 3, 2011 at 8:29 am #352676Enfys
Ok, thanks. I’ll see if I’ve got another coreboard with one of the other machines I’ve got lying around, if not, I may just sell another working one, which has got to be better for the Customer. Appreciated your input
June 3, 2011 at 10:52 am #352677Enfys
Looks like I can get it repaired on a same Day Service now for around £40 inc vat. I’m going to give that consideration.
