Pcb only half lit
  • #89776
    silvergb
    Hi, can anyone tell me why the display on my Hoover DYN 9164 is only showing half the digits , ie. shows only E instead of END when finished. Also is a new pcb easy to fit please?
    #442493
    Re: Pcb only half lit
    Could just relate to a connection problem so you’ll need to go inside and check. Beware, it’s 240 volts in there so power disconnected first. :plug:
    #442494
    kaibart
    More than likely the display board has failed isn’t to bad to change but pricey though I would just live with it when you see price on new pcb
