I have recently replaced a couple of heater relays on the modules of 2 dishwashers I repaired. After reading the recent threads about changing a relay and a fuse on a Miele module, and in the pcb tips I was wondering if anyone can answer the following
1 Of the 5 pins used which ones are used for what?
2. What sort of ohms readings can I expect from which pin?
3. Can any readings be taken without desoldering the relay from the board?
Thanks in advance
Graham
