Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › pcb wireing for apm6852 //old board to new
- This topic has 7 replies, 3 voices, and was last updated 11 years, 7 months ago by
davebaron.
September 3, 2014 at 7:01 am #82082
davebaron
Participanthi guys would any one have the wireing diagram for this please the old pcb has 8 and the new one has 6 if it helps the link for the part is http://shop.ukwhitegoods.co.uk/51025200 … reezer-pcb thanks ..dave
September 3, 2014 at 7:12 am #418658SAMURI
ParticipantRe: pcb wireing for apm6852 //old board to new
The part should have came with the wiring mod.
I will look tonight when I have more time to see if I can find it in my paperwork.
You could try AWS to see if they can help.
But I would contact the part supplier you ordered it from.
I can remember 2 of the wires are for the sensor and are not required as the sensor is on the new PCB.
BobSeptember 3, 2014 at 7:21 am #418659davebaron
thanks bob ..if I tell you I got it from connect and I rang them regarding it ..there were as much help as xxxxxx so that’s why im on here for help so thanks again.
September 3, 2014 at 4:22 pm #418660SAMURI
Hi Dave
To change from the 8 pin module to the 6 pin details below.
Working from left to right.
Left large brown wire pin 1
Right thin white wire pin 8Remove wires 5 & 6 and insulate them this was the old sensor.
The thin brown wire pin seven goes to pin 5
The thin white wire pin 8 goes to pin 6 this is the reed switch wires.
Hope this helps
Bob
September 3, 2014 at 7:02 pm #418661davebaron
thanks bob your a star
September 3, 2014 at 7:27 pm #418662SAMURI
That’s ok the pin 1 brown wire is the main live wire
The pin 2 is the compressor feed.
Pin three is not used
Pin 4 is the neutral
Pin 5 & 6 is the reed switch
On some models I have found the wires are different colours for the sensor but the wiring positions are the same on the PCB so just go by the PIN numbers.
You just take 5 & 6 off and insulate then fit 7 to 5 & 8 to 6Bob
October 23, 2014 at 2:58 pm #418663comptonappliances
Hi did anyone get hold of the PDF wiring for this subject is so can you please help thanks
October 23, 2014 at 3:24 pm #418664SAMURI
Look at the instructions before your last post.
Bob
