Home › Forums › Public Support Forums › Help And Support › Other Appliances › Philips GC8260 Pressurised Steam Generator – No Steam
- This topic has 7 replies, 3 voices, and was last updated 6 years, 10 months ago by
sdancer75.
May 27, 2019 at 7:02 pm #95919
sdancer75
ParticipantI have the Philips GC8260 pressurized steam generator. The problem is that I have no steam.
I checked almost everything and I decided that the fault is the water pump. So my question is, can this work (I can hear a sound at least at the begging) but there is no water in the boiler. Is there any way to ensure that the problem is the water pump? If I manually fill the boiler with water then I have steam.
PS: I have heating, I changed the PCB capacitors and I also checked the thermistor and fuses. They are all good.
May 27, 2019 at 11:12 pm #461728electrofix
Moderatorif the sound you can hear is the water pump energising and it not pumping the water then its likely the pump has failed (unless you have a blockage)
did find service manual but may be of use
https://www.manualslib.com/manual/98…60.html#manual
DaveMay 28, 2019 at 10:56 am #461729sdancer75
Participantelectrofix wrote:
if the sound you can hear is the water pump energising and it not pumping the water then its likely the pump has failed (unless you have a blockage)did find service manual but may be of use
DaveI tested the water pump on the bench. It works but it not pumps !!
May 28, 2019 at 1:35 pm #461730don
ModeratorLeaving water in the tank when not in use can cause issues, try an iron descaler once you have reassembled it.
Don
May 28, 2019 at 2:57 pm #461731sdancer75
Participantdon wrote:Leaving water in the tank when not in use can cause issues, try an iron descaler once you have reassembled it.
Don
Don thanks, but I never left water in the tank when the iron is not used.
Also, iron descaler should not help there, I ordered a new water pump. Still, I don’t know if these kinda problems are usually on steam generators.
May 28, 2019 at 7:28 pm #461732electrofix
Moderatoryes these sort of problems are normal
its mechanical so it can fail
May 29, 2019 at 1:22 pm #461733sdancer75
ParticipantNew pump solved the problem.
Question : What sensor is used to sense low water/steam inside boiler to decide when water pump should start working ?
May 29, 2019 at 7:01 pm #461734electrofix
ModeratorI would assume the thermistor on the tank. as the water get lower the temp will rise as it runs out of water
(but cant be certain)
