Customer says drum not turning and is making grinding noise. I’m thinking belt snapped and motor pulley is rubbing on tensioner arm?
Only reference I can find to this model shows a Crosslee lollipop type element as fitting it. Does that make it a 1956J3 belt as per AWB650?
Come on you old hands.
Mike.
Turned out to be a AWB159. It turns out the right belt for that is 1925/1930 j3 so the 1905j3 I got from Masterpart by some fluke (listed as fit for AWB650) just fitted with a bit of a stretch.
Thanks, Squadman.
Mike.
