Philips Slimstar MK3,AWB 147PH
Home Forums Public Support Forums Spare Parts Help Philips Slimstar MK3,AWB 147PH
  • #42812
    rufstwo
    Does anybody know where I could get a timer for this washing Machine ?
    I’m sure I can hear a chorus of derisive laughter but I have to try !
    #274998
    Re: Philips Slimstar MK3,AWB 147PH
    Long time obsolete…..
    Might be worth a call to ASD Services on 0113 393 6680 – Whirlpool spares specialists; might have one in the back room somewhere.
    smartin
    what makes you think the timer has gone ?
    #275000
    rufstwo
    Hello smartin
    The Timer consists of two columns of segmented discs.The main column,which assigns power to the various elements of the selscted programme is fine.The problem is with the secondary array which performs the function of reversing motor rotation and,when needed,switches in the demand for spin.The selection mechanism is worn and intermittently fails.It is probably more than 20 years old and very tired.I can overcome the mis-selection manually by advancing the appropriate cam but would prefer to replace the timer.
    #275001
    rufstwo
    Hello penguin45
    Thanks for the advice.ASD services did not have the part-no surprise there.But at least I’ve received confirmation that as I suspected were I able to replace the timer I’d possibly get more years service out of this machine than its modern replacement.
