Philips/Whirlpool AWM822 automatic washer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Philips/Whirlpool AWM822 automatic washer
  • #26691
    Dales-Electronic
    I’ve been out to one with a broken door latch return spring, Could someone please advise how to get the outer door frame off (without breaking it) so I can remove/replace this spring. Cost of new door frame exceeds the value of the machine. Thanks.
    #211082
    SparkyP
    Re: Philips/Whirlpool AWM822 automatic washer
    Depnds how you want to do it. Either with the door on the hinges or off. I prefer off as there is more space to work. Take an 8mm box spanner to the 2 bolts on the hinge. The door handle just comes off with a flat blade underneath and pull towards you. The outer rim will just clip on and off. Take it off with a flat blade between where the inner and outer rim meets on the door then slide it around and the rim pops off. A pair of long nose pliers to get the pin out of its holding. Also check the plastic door hook for cracks. Hope this helps.
    Sparkyp
    #211083
    Dales-Electronic
    Thanks Sparky – done and dusted 😀
