Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › please advice needed again
- This topic has 4 replies, 3 voices, and was last updated 18 years, 4 months ago by
brightonuk2006.
November 27, 2007 at 5:41 pm #32550
brightonuk2006
ParticipantHi i posted a thread here a few weeks ago now about my indesit is70c condensor drier which i had burnted out something by resting t on a mattress to make it less noisy anyway i have taken it apart and found that on the heating element(i think its called that the springey type thing?)that one of the springs had a break in it would this cause it to not heat up ?? im going to replace this broken part anyway but could there be any thing else that would cause it not to heat up?? any advice would be great many thanks gavin 😉
November 27, 2007 at 6:42 pm #235544Penguin45
ParticipantRe: please advice needed again
Did you get the motor running again?
Broken coil in element will cause half heat (double element). No heat at all will be the safety thermostat tripped out due to the motor stopping.
You will need:
http://shop.ukwhitegoods.co.uk/product_ … ts_id=1127
and
http://shop.ukwhitegoods.co.uk/product_ … cts_id=717Power off………
November 28, 2007 at 9:19 am #235545brightonuk2006
hi thanks for your advice again the motor was always working i presume by motor you mean the motor that spins the drum? please correct me if you was talking about another motor?anyway the fan at the back spins great and the drum goes around ok its just the lack of heat thats the problem i got no problem replacing these parts if this will hopefully solve the problem would these parts be the only thing that would cause it not to dry? my concern is me getting both these parts and it still not working 🙁 anyway where can i find the thermostat? ive had the top off and found nothing resembling a thermostat would it be on the side near where i unclipped the heating element.? thanks again for a speedy response regards gavin
December 9, 2007 at 11:45 pm #235546matt_tee
the thermostats are just above the heater elements, hidden underneath.
December 10, 2007 at 12:32 am #235547Penguin45
Or even on top, in full view when you pull the heater out……
