Please help
  • #89202
    lee786
    Beko cda659fs/1
    Past few days I have noticed a change in noise this carrys on going for some time after the machine is switched off so I doubt it’s frozen fans
    Compressor is on all the time and it’s too hot to touch the grill on the back is also getting hot at the top and bottom
    The freezer is working and air coming from it is as cold as ever but the fridge isn’t cooling as well as it should definitely not as cool as normal
    Things I have tried
    I defrosted it for about 8 hours
    I have taken the service panel from the back of the freezer off
    The drip vent for that was iced up and that’s about it (cleared that)
    The fridge is a sealed unit so can’t get at anything from that.
    Really stuck here because I’m out of work and really can’t afford this
    Right now could do with some advice
    #440627
    Re: Please help
    It could be the sensor in the fridge or the evap one but from the description it could just as easily be a naffed compressor.
    Sensor not so bad. Pain to change but can be done.
    This one if you need it:
    http://shop.ukwhitegoods.co.uk/43947202 … air-sensor
    With more info on them here:
    http://www.ukwhitegoods.co.uk/help/fix- … hermistors
    If the compressor is gone it’s a death sentence I expect as that’s not repairable DIY and not cheap.
