Please help identify this Ariston oven…
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Please help identify this Ariston oven…
  • #45817
    Andrew1967w
    I need to get replacement door seal, but need the model number.
    Many thanks…
    Andrew
    #287138
    spimps
    Re: Please help identify this Ariston oven…
    You will ned the serial number too which we couldn’t give you and will only be on the cooker.
    The model and serial numbers are found when opening usually the bottom door and are on a plater around the edge of the inner face of the cooker,it’s there somewhere 🙂 it may only be 20x60mill.
    Failing that release the cooker by taking out the 4 or 6 screws which fasten it to the cupboard surround and slide it forward and there will be a plate on the carcase with the details on.
    #287139
    Andrew1967w
    There is a label inside the door it says:
    Part number 0167****
    Serial Number 91016067
    The rest of the part number has been worn off!
    The part number doesn’t appear to correspont to any part number I can find on any of the “spares” sites.
    #287140
    spimps
    There are models listed from 016704 to 016708 so it could be any of those,perhaps if you call Ariston an understanding spares clerk might try and match the mod to the serial no.
    The other option is to slide the machine forward and check on the casing for the info,unless of course you can find the paperwork from purchase or installation which will help.
    BG
    #287141
    spimps wrote:There are models listed from 016704 to 016708 so it could be any of those,
    Have you tried to look up any parts for those models numbers spimps, no parts found for any of them. 😥
    #287142
    Got it. 😀
    Model is a TC714. 016704/8 are the commercial codes for colour varients.
    Main oven door seal is a C00152985…Top oven is a C00156621.
    An e-mail to spares@ukwhitegoods.co.uk will get you cost and delivery info.
    Andrew1967w
    Fantastic!
    Thank you very much. I really didn’t want to pull the oven out…
