Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Please help – Indesit WIDL 126 flashing
- This topic has 7 replies, 4 voices, and was last updated 17 years, 3 months ago by
natalia.
January 10, 2009 at 1:02 am #42447
natalia
ParticipantDear all,
I would be extremely grateful if someone could help me understand what this code means. Unfortunately, I do not understand if the lights flashing are 1, 2 ,3 or 4, as this model has 4 vertical lights (delay timer) and 4 horizontal lights. On mine 6 lights are flashing very quickly: all horizontal lights + the forth (bottom) vertical light (9 hour delay) + the door lock light…
Indesit quoted me £90+ for the visit, but I can’t really afford it at the moment so would be very grateful for any advice.
Many thanks in advance,
NataliaJanuary 10, 2009 at 1:26 am #273526Penguin45
ParticipantRe: Please help – Indesit WIDL 126 flashing
All four horizontal lights flashing suggests a problem with the pcb supplying power to the dryer section. This is inevitably a problem with the computer board.
No cheap fix, I’m afraid.
January 10, 2009 at 1:48 am #273527natalia
Thank you so much for a quick response. That’s bad news though… Will at least try to find a cheap engineer.
Many thanks again.
August 31, 2010 at 3:35 pm #273528laurentiu
I had the same with a Indes***t WIDL 126S EX washing machine. I changed from the PCB the big polarized condenser (22u/400V i guess) which is part of the power supply, and the flashing is gone. The other problem is that i didn’t put it up on the washing machine so I do not know how it act. I just verified it with a front panel which I had in the house.
August 31, 2010 at 3:42 pm #273529laurentiu
laurentiu wrote:I had the same with a Indes***t WIDL 126S EX washing machine. I changed from the PCB the big polarized condenser (22u/400V i guess) which is part of the power supply, and the flashing is gone. The other problem is that i didn’t put it up on the washing machine so I do not know how it act. I just verified it with a front panel which I had in the house.
I’m long time near the subject, but anyway if someone knows other then me and Penguin45 may come and continue the subject.
September 17, 2010 at 12:37 pm #273530laurentiu
I come back with a compet solution ! The big capacitor (22u/400V) and the EPPROM replaced ! It works great now !
September 17, 2010 at 8:48 pm #273531helo_75
Participanti THINK id be ignoring the last 3 posts .. none of it made any sense and wasnt helpful.. as engineers we always advise a safe repair.. yes, it is possible to repair the pcb to component level, if you feel confident enough, and want to do that its fine, but we advise a good, safe piece of advice to help you work safely!
anyway, good luck
September 18, 2010 at 12:06 pm #273532laurentiu
ParticipantToday I had to fix a WIXL 106 EU. The problem was the same. I made the same change in capacitor without changing eeprom and the wm works great.
helo_75 wrote:i THINK id be ignoring the last 3 posts .. none of it made any sense and wasnt helpful.. as engineers we always advise a safe repair.. yes, it is possible to repair the pcb to component level, if you feel confident enough, and want to do that its fine, but we advise a good, safe piece of advice to help you work safely!
anyway, good luck
Off topic- I know what engineers advise, I am one, but unfortunately I am a engineer in a different country than yours. -
