Re: Please help: Leibherr fridge freezer KGB4046 24c/001
Hi James look at the bottom of the cover underneath. There may be 2 T15 torx screws there. You’ll have to pull the divider out too.
Also, roughly halfway down the cover at either side, should be little white plastic caps that come off revealing more T15 torx screws.
Be careful pulling the cover away from the evaporator as there is a connector for the fan and also sensors in there.
Cheers.
