please help with some advice on my fisher & paykel
Home Forums Public Support Forums International Forums Australasian Appliance Forum please help with some advice on my fisher & paykel
  • #13451
    aussie white
    Hi guys wonder if you can advise me of some help, we have a fisher & paykel 703, the seconed rinse light (from the left yellow in color) flashes with the hot and cold lights. the machine takes a very long time to run through cycle ie;4hrs stops every now and then and alarms. It is very slow to fill with water. Fisher & pykel advised me that it has bad water pressure. we have checked the hoses cleaned the hose filters checked the taps and pressure from them and all seems to be ok. Can you please give me some advice we have had a service man tell us that the machine is no good. your help would be much appreciated
    #154995
    Re: please help with some advice on my fisher & paykel
    If I am to believe the manual, you have two problems.
    1) Hot and Cold flashing is basically insufficient water supply – not filling fast enough.
    2) The rinse light flashing suggests that the load is out of balance.
    The two together is rather unlikely, so your best bet is to run the diagnostics and see what you get, then report back.
    If it is flashing on deep rinse and the H + C lights are flashing, it is the cold valve that needs replacing.
    Check it out 8)
