I am in a new place and was installing my W/M – but one of the plumbed water pipes has a flat ended nut that is presumably to prevent water being supplied to a machine. i.e. only one of the feeding pipes is uncovered.
Apologies if this is a dumb question, but is it safe to just remove that nut, and assume the water will flow normally, to the W/M?
Also, the pipes are well hidden, and go through a wall, so its not really clear which is hot and which is cold. Is this a problem for fitting to the washing machine, or can hot and cold go in either inlet? Its a Margherita 2000.
The landlord is travelling so not easy to check up with him.
thanks alot
Gavin
