Pongin Bosch fridge
  • #20305
    MD
    Morning
    I have a Bosch Excel fridge ktr15424gb/01 fd8412 class tn153
    I seem to recall its supposed to be frost free. Problem is – it pongs. The drain at the back leads into a plastic reservoir on top of the motor. This has wate in it – some at least. It went mouldy a while ago and the heat from the motor is slowly cooking it. What an ugly niff. I cant see any way of removing the reservoir to clean it as there isnt enough room.
    Any ideas welcome. I’ve already used a towel to drain it as much as poss but the problem has returned.
    cheers Marc
    #186568
    gegsy
    Re: Pongin Bosch fridge
    Resevoir will pull off, but you will need some means of sticking it back down again. Sticky pad strips etc.
    Un plug before attempting please. :plug:
    MD
    Cheers Greg – but theres not really enough room above it to do this without breaking it or spilling the contents. Its really quite tight.
    Thanks Marc
    #186570
    gegsy
    Yes quite tight, try and get a cloth in to soak up, Then pull gently.
