positioning of a compact/mini freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum positioning of a compact/mini freezer
  • #32409
    skoop
    Hi. I have one of these
    (Zanussi ZUC053W).
    I initially had it on a table in the kitchen but am thinking of putting it on the floor. My question is – will the floor perhaps being a bit colder cause any problems? I could put it on a board or something though.
    I noticed condensation under the freezer/on the table top and wondered if it might get worse on the floor. However there is a damp problem in the kitchen at the moment and once that gets sorted condensation might be a bit less likely.
    (The freezer’s is pretty new and only been in use 3-4months so it shouldn’t be faulty in any way. The problem seems to have gone since there’s been a dehumidifier in the kitchen)
    #235003
    So long as you follow the climate class guidelines for the unit (it should be on the rating plate) then it should be fine.
    You can get the recommendations from from this article
    HTH
    skoop
    Re: positioning of a compact/mini freezer
    thank you
