Possible Heat Pump Dryer
Home Forums Public Support Forums Buying Advice Possible Heat Pump Dryer
Viewing 15 posts - 1 through 15 (of 15 total)
  • #93061
    kezwald
    Any help/advice would be gratefully appreciated.
    We are a family of three but with a difference our daughter is special needs/disabled so realistically more like a family of 4-5. We currently have a Samsung 9kg eco bubble rubbish. It is on I would say its on at least 5 times a week some days can be twice a day, so not a light user I would say.
    Currently we have a 9yr old 6kg Beko vented in the garage which is well maintained (hence probably the long life span) I now need to bring a TD in the kitchen rather than keep going into garage for safety reasons (daughter). It will be almost impossible to go the vented route due to the kitchen layout.
    So here comes me thinking I come under the few people where a HP would be beneficial, Also thinking I need something a little better than Beko HP but cant warrant the cost of a Miele, so looking at a Bosch.Serie 8 to get 9kg
    The 2 i have looked at are the WTW87560GB & WTWH7560GB only difference one has home connect ( pointless IMO) but is also newer so may of ironed out some of the issues on the former.Both i can get around £650 to buy.
    The main issues i have is the Serie 8 :
    !/ Drums dont auto reverse, bedding getting tangled, although this can happen in my current machine
    2/ Self clean condenser !! (not easily accesible) on the plus side i can do a flush of the condenser/pump in the engineer mode,so on the flip side of the coin is this actually better than one you manualy need to clean frequently ?
    Happy with any help/suggestions or otherwise please
    #453026
    Re: Possible Heat Pump Dryer
    Condenser dryer are high maintenance in comparison to vented. Heat pump dryers take much longer to dry than conventional condenser dryers. Bosch umm? Not brilliant, Zanussi or Beko better.
    You’d be hard pushed to find a reverse tumble from that lot as well. 🙁
    #453027
    Heat pump dryers
    #453028
    kezwald
    Martin wrote:Condenser dryer are high maintenance in comparison to vented. Heat pump dryers take much longer to dry than conventional condenser dryers. Bosch umm? Not brilliant, Zanussi or Beko better.
    Interesting you would put Zanussi or Beko above Bosch, is that from a quality or repair point of view. Having said that must admit never had a problem with Beko and my previous Beko WM was far better than current Samsung.
    Something i did think was odd was Which seem to favour Bosch over Miele with these 😮
    I know about this stuff from an industrial point of view, but no idea how it fares in a domestic situation hence coming to you the experts. What i am trying to decide is it feesable at home considering the amount of laundry that gets done…would i save electric TBH i dont know in the real world.
    #453029
    don
    To put another slant on it 😉
    Bosch do not make their own dryers, personally I think they are not good value for money.
    If it were me I would go condenser dryer with a mechanical timer like the Hotpoint FETC70P. No sensors granted but a lot less to go wrong.
    As said before Zanussi and Beko with no sensors would be another good choice.
    Don
    #453030
    kezwald
    don wrote:Hi
    Don
    Hi Don isnt the FETC70P one of the Fire Risk appliances, even though i do regulary maintain my current Beko with Mr Henry vac, think the wife would divorce me if she found out LOL
    #453031
    don
    Yes it was one, but all the new variants of each model number have now been modified in production. So no more problems.
    Any tumble dryer you purchase should be cleaned afer each cycle irrespective of the brand and model.
    Don
    #453032
    Whilst not wishing to step on my good friend Don’s toes I would be wary of using any current Hotpoint dryer of this type if it is going to get heavy use.
    Although the fire risk problems have been sorted it is still using the same rear drum bearing that is very prone to failure. the old square bearing used to fail rapidly but the current teardrop bearing is still not up to heavy use and wears right through leading to drum shaft failure if not caught in time.
    #453033
    Beko DCJ83133W……nice 😀
    #453034
    don
    Fair Shout iadom I was trying to keep it simple in order to prolong the life. The Beko ranges of late we have had issues with boards and heater failures ( sorry Martin) which leaves as far as I can see the Zanussi range.
    Don
    #453035
    kezwald
    Thanks guys for all getting involved here.
    ideally could do with 9kg to match WM so any more you can suggest.
    i did like the idea of the Beko Martin pointed out with see through door, more aesthetically pleasing to the eye with going in the kitchen.
    TBH not to fused on the Candy nor Indesit groups anyway, Gues that puts Hotpoint out sorry Don
    Electrolux i do come across these in work, although i do have a friend who use to have an AEG TD that sounded like a tractor, The question is do i have a puntt at Zannusi or not i don’t know.
    Any further suggestions welcome Please and possibly something a bit more economical to run
    #453036
    kezwald wrote: possibly something a bit more economical to run
    Still several of THESE in use in these parts. 🙂
    #453037
    kezwald
    😮 Thought they went out with the arc, Brings backs memories of my Great Grand parents when i was a kid having one of those over the tub after it been run through the mangle 🙂 how things have come on over the years
    #453038
    Great Grandparents………my daughter still has one that does get occasional use. 8)
    She draws the line at using the Dolly Tub, Posser and Mangle though. 😆
    Fine in older properties with much higher ceilings than modern houses., often used for decorative purposes these days though.
    #453039
    don
    We have one which is used weekly, excellent bit of kit 🙂
    Don
