Possible problem with Whirlpool fridge-freezer ….
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Possible problem with Whirlpool fridge-freezer ….
  • #36685
    swayzak
    hi
    Firstly I should say that I don’t know the model of this fridge-freezer – I’ve just moved into this house & it’s fitted into the units (and no visible ID plate).
    The appliance works – but the pump seems to run almost all the time !
    The only way I can get it to cut out is to turn the thermostat right down to 1 or 2.
    Then when I set it to reasonable number, say 3, eventually the pump comes on … but then never seems to cutout again on it’s own.
    Is this normal ?
    thanks
    swayzak
    #251937
    Simon46
    Re: Possible problem with Whirlpool fridge-freezer ….
    What does a fridge thermometer say regarding temperature?
    S.
    #251938
    swayzak
    thanks
    Ah, haven’t got one yet …. is top of shopping list.
    I’m used to running fridges at 3+, but if I try it with this one, the back of the compartment gets iced up.
    Is there anything common/obvious that would result in the pump/compressor not turning itself off (but can be turned off by turning the thermostat down) ?
