Re: Power cut halfway washing cycle on indesit iwme126
Bad luck and it would be an intergrated appliance! Sadly it is usually the power, bottom r/h/side corner, pcb has had it.Visually check this pcb but you might not see anything at fault or it might be visible from 100 yrds and blown up! BUT I`d also check motor brushes and the wires to the door interlock ( I`ve had the wires burn out at the interlock connector and the wires to the facia panel pcb just in case, first two are common faults.
Note I`m pretty sure that any brand new pcb will be blank = won`t work unless either programmed via Indesit on site via their trusty money making lap top or you can buy a very expensive gizmo card reader that plugs in to the new pcb with a the suitable smart card for your model that slips into the reader, conclusion: you`d be well financially hammered either way. Only other suggestion is to get the pcb repaired if possible, QER in Cumbria perhaps? or buy a used one off ebay from a scrapper advertized for your model. Would of thought it will be easy to get then it`ll just be a case of swapping the wires over to s/hand pcb and hopefully all other things being checked before hand with fingers X`d it should then work.
