I have a Bush hw60-1460d
With ‘err2’
I have discovered this means that I need to..
- Check that filter is not blocked or obstructed[/*:m:3m1suoy7]
- Check drain hose is clear of any blockage or obstruction[/*:m:3m1suoy7]
- Check wiring to drain pump[/*:m:3m1suoy7]
- Check drain pump is not defective[/*:m:3m1suoy7]
- Check level sensor or switch[/*:m:3m1suoy7]
- Check wiring to level sensor[/*:m:3m1suoy7]
But I’ve never lived in a place where I had to do it myself. And my housemates don’t seem to care in the slightest, they go ‘oh’ and then walk away.
I have no idea where the filter is, or if I can get to it, as I also have err1, meaning that the door is locked and unresponsive.
Any help would be great.
