‘Premier’ Type E72A/B14401TE oven thermal cut out
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts ‘Premier’ Type E72A/B14401TE oven thermal cut out
  • #90000
    Washdisher
    Main oven thermal cut-out required for the following double oven:
    Premier Type E72A/B14401TE
    Serial Nr 1012510034
    FDAEE5050002044
    BAND D7 SV441E
    Details on the cut-out:
    Campini TY60, 10/250 18/250 T210
    Looking at other posts, I think this may be a Delonghi – it is made in Italy. Any help gratefully received.
    Derek
    #443232
    Re: ‘Premier’ Type E72A/B14401TE oven thermal cut out
    doing a search found a post with a similar subject
    viewtopic.php?f=36&t=3197
    but digging a bit more found possible smeg part number SMG818730625
    have posted a picture from Qualtex and they are showing stock
    the only thing I can be sure of is the picture actual or generic you would have to order and check or ask them. checked connect and they say it 90 degrees so I don’t know
    hope this helps
