Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Prima LPR 600/1 Fails after a few minutes with beeps
- This topic has 7 replies, 4 voices, and was last updated 16 years, 9 months ago by
Uresu.
June 19, 2009 at 10:46 am #46489
Uresu
ParticipantManufacturer : Prima
Model : LPR 600/1
Barcode Sticker code 1 : 8545 600 15880
Barcode Sticker code 2: 33 0814 009286Hi There,
The above machine starts it’s cycle and after a few minutes emits 3 short beeps followed by 1 long beep.
We actually had the problem before, but after cleaning filters and stuff it went away. Does anyone know the actual cause of this fault code?
Thanks!
June 19, 2009 at 11:48 am #289619Simon46
ParticipantRe: Prima LPR 600/1 Fails after a few minutes with beeps
how many flashes does the light do?
S.
June 19, 2009 at 12:03 pm #289620Uresu
The dishwasher is fully integrated, there are no lights visible when the door is closed. I presumed that’s why it beeps instead 😀
June 19, 2009 at 12:23 pm #289621Simon46
Then open the door. flash code should repeat itself with a pause inbetween.
S,
June 19, 2009 at 12:52 pm #289622Uresu
I waited for the beeps to finished and opened the door.
The program selector like was on the program I had selected and the start/running light was of. Just like it would be if it had finished a cycle, but as I say, the cycle only lasts 2 minutes :/
I really appreciate you helping by the way 😀
June 20, 2009 at 4:13 pm #289623Penguin45
It sounds like the pcb has failed in some way.
Try selecting a programme, press srtart and shut the door. As soon as you hear the drain pump cut in, open the door and press and hold the start button until you get the beeps, shut the door again and wait for the drain pump to stop. Try programming again. It may do the trick but I wouldn’t bet on it.
July 16, 2009 at 7:35 am #289624Uresu
Nope.
I ran it on each program and it started working again. Clearly not the PCB.
May 17, 2010 at 12:18 am #289625V6Jim
I have PM’d you regarding an identical fault I have with my Prima LPR600/1.
How did you fix it? Is it still fixed?
HELP!!
Jimmy
