my prima lpr 600 dishwasher is filling with water and when going onto wash cycle it starts to beep and drains all water away. Beeping continues until opening the door. i have tried re-setting but to no avail. the indicator light flashes 11 times and then stops and flashes 11 times again and keeps on doing this. all drains seem clear and water being let in. any ideas
It sounds as if you have a a problem with either a blocked or faulty water sensor.
If you do a search on here for Whirlpool; which is basically what your machine is, you should be able to find more info 😀
