PRIMA LPR600
  • #11162
    machineman
    Hi guys prod number 854560015810 this m/c just pumps and beeps no matter what prog you put it on, it goes back to the first prog and beeps. checked for flood switch ,it hasnt got one. any suggestions would be helpfull.m
    #144188
    goosegreen
    Re: PRIMA LPR600
    Machineman had the same problem last mth on exactly the same model after asking for advise on the forum it turned out to be the NTC was O/C
    Goosegreen
    #144189
    Dave_Conway
    Re: PRIMA LPR600
    It’s this thread m:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=6730
    #144190
    goosegreen
    Re: PRIMA LPR600
    I would have done that Dave but not sure how to link to the thread
    #144191
    DentedPorsche
    Re: PRIMA LPR600
    Count the flashes on the start button. Single flash is NTC.
    It’s a whirlpool machine, rest of the codes are posted.
    Brian
    #144192
    machineman
    thanks guys will have a look again, flashes continually dp .m
    #144193
    DentedPorsche
    Re: PRIMA LPR600
    That’s most likely a single flash, new ntc should cure it.
    Brian
    #144194
    machineman
    is this a standard whirlpool ntc.m
