prima lpr600
  • #55804
    gixer
    HELP. my dishwasher has suddenly stopped working as it should. i put it on the 50 setting and not long later i heard a beeping sound. this was constant and would only stop when the door was opened or when switched off.
    i have tried to run a new cycle again and were as normal after closing the door i hear a sound as though a though a pump is switching on and sucking water through( best way i can describe this) now i cannot.
    after closing the door the sound of water being sprayed can be heard after about 4/5 minutes. the sound can be heard for about another 5 minutes before going back to the problems of the beeping sound.
    what i have noticed is that all the water is just sitting on the bottom of the machine and doesnt appear to be draining away.
    CAN ANYONE HELP ME ON THIS MATTER
    THANKS
    #325201
    Re: prima lpr600
    Ignore the beeping, count the pattern of the flashing start light; ie – 1-2-3-4-pause-repeat.
