prima lpr600 beeping, but not starting – please help!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum prima lpr600 beeping, but not starting – please help!
Viewing 15 posts - 1 through 15 (of 21 total)
  • #8168
    naomignomes
    Posted this before but wouldnt let me use my username so am posting again now i have worked it out!!!
    My Prima dishwasher (we have no instructions for it) will not start. you can get to choose the cycle, and then press start and close it, but it then goes straight to rinse cycle and beeps continuously. The beep is a short beep which happens once every second or so, without a longer pause. it is continuos. you can hear something trying ot work inside the machine, but it wont do anything else! Please help! Thanks.
    #127133
    Alex
    Re: prima lpr600 beeping, but not starting – please help!
    May need a bit more information.
    Prima is sometimes a “Badge” name for a product unique to the kitchen company, and may be one of several manufacturers.
    Take look and see if there is a production number, i.e. pnc 91100000-01
    That may point us in the right direction.
    #127134
    DentedPorsche
    Hiya,
    This one appears to be a Whirlpool in disguise. There are two models using the model number you gave, the 12 digit model number helps identify the exact model and you can find this on the right hand side of the door when you open it.
    If you count the flashes between the pauses on the start button light, post the result here and someone will let you know what the error is.
    If it appears to flash continuously with no pause then this is F1 fault and indicates an NTC problem.
    Hope this helps.
    DP
    #127135
    naomignomes
    The beeping starts straight away and the only pause there is is a second or so between beeps – it is relentless! We have to take a cupboard door off to be able to get round and see the 12 digit number, but will do so in a bit and post it asap. thanks. whats a ntc fault?
    #127136
    Temperature sensor, or associated wiring, or related control circuitry. Can be awkward.
    #127137
    naomignomes
    The 12 digit number from the right hand side is :
    330316009345
    does that help at all?
    #127138
    DentedPorsche
    Hiya, that’s the serial number. There should be another 12 digit number before it and it’ll be either 854560015810 or 854560015860. However, the serial number indicates a Whirlpool machine. When it starts beeping, open the door and look at the light by the start button, this should be flashing, count the flashes between pauses. The number of flashes will translate to an error code. Once we have this we can give you an indication of the likely fault.
    DP
    #127139
    naomignomes
    the number is 854560015810. With regards to the light flashing. it doesn’t really pause, just flashes on and off continually. Thanks.
    #127140
    naomignomes
    So is this a problem I can fix myself or do I need to get someone in to do it for us?
    Thanks,
    Naomi
    #127141
    DentedPorsche
    Sorry, I think it’s engineer time, it looks like an F1 error which is the NTC.
    However, the error codes are only a guide and the fault may lie elsewhere. Probably cheaper in the long run to have it checked out by an engineer rather than throwing parts at it.
    DP
    #127142
    naomignomes
    Hiya – an update on our dishwasher!! And a request for help again!!! We had an engineer out on Friday morning. He fixed it, by resetting the control panel or something. Sound familiar? he charged us £55 for the ten minutes he was here, a standard call out fee – money well spent to get it to work – but come yesterday (saturday) it starts beeping again! Can we reset it ourselves or are we going to have to pay the man to come out again??? What could be casuing this as we dont want it to break every day!! Any ideas? Thanks!
    #127143
    DentedPorsche
    Press and hold the start button for 10 seconds (ish) and it’ll reset. However, this isn’t a cure. If it’s back to a single flash, you have a problem with the NTC.
    DP
    #127144
    Gazza1701
    I Have the same problem, Starts to pump out, keeps pumping for 4-5 mins then beeps continiously an wash setting goes back to rinse.
    Did spot the power light flash 4 times then pause.
    Any one have any thoughts?
    #127145
    Dave_Conway
    4 flashes or F4 is a no drain error. Check for blockages where the waste hose joins the sink trap (if it does) for a starting point 🙂
    #127146
    Gazza1701
    Hi Dave
    No blockage, put water in machine and it pumps out fine, pump goes on for 4-5 mins then flashes the f4 error code. does it have a float orpressure switch to know when it is empty?
    Regards Garry
