prima lpr600 beeping, but not starting – please help!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum prima lpr600 beeping, but not starting – please help!
Viewing 6 posts - 16 through 21 (of 21 total)
  • #127147
    Gazza1701
    Re: prima lpr600 beeping, but not starting – please help!
    Me Again
    Have remover front cover to expose pump Etc and found that the bottom tray is full of water, about 1 cm deep. no immediate sign of where it has come from.
    #127148
    Dave_Conway
    Ah, flood protection activated the.
    If you drain the water off it should work but the source will have to be identified if it recurs.
    Power off when covers removed of course :zap:
    #127149
    Gazza1701
    Problem Found. Small hole in hose from pump to sprinkler rotor arms, also lots of cuts in my fingers!! 😆
    #127150
    Dave_Conway
    What did you do to resolve it ? 🙂
    Whirlpool’s solution is a complete spray pump motor at just under £100 as the hose is moulded to the pump housing 😯
    #127151
    Gazza1701
    Hi Dave
    Removed old rubber hose, carefully cut off the moulded rubber on the pump housing, fitted a 1 cm length of 25 mm hose on the sprinkler moulding and then pushed a 5 cm length of 32 mm hose on top of it and onto the pump housing. Both ends held in place with a jubilee clip. Hope that makes sense. Works a treat. Definitely not paying £100.
    Garry.
    #127152
    Dave_Conway
    Thanks for that, hopefully it will help future readers resolve the problem 😀
