PRIMA LPR600 Dishwasher
  • #91312
    char14lew
    service no. 854560015810
    This is the whirlpool non display model, flashing from what I can make out twice which indicates water leakage, but non in base or trace anywhere else!
    As it worked fine a few times when put on test and now is beeping and flashing when trying to set away all cycles, i’m thinking it could be pcb related?
    Anyone had these issues before?
    read the threads, but couldn’t see anything related.
    cheers Darrell
    #447714
    Re: PRIMA LPR600 Dishwasher
    full parts and test info for this are in the place i sent you
    have you checked the switch and wiring is not faulty. dont know if this switch is normally closed or open
    very common fault on these machines is the door wires have you checked them ?
    char14lew
    I have all the info from what you sent Dave thanks, am going today as first visit just basically popped in to see what brand of prima it was and problem!
    looking on the threads, looks like a problematic machine so thought would throw it out there!
    thanks for your reply
    Darrell
