I’ve an integrated diswasher labelled Prima LPR600. It’s got a door attached to match the other kitchen cabinets, but the handle needs replacing. How do I get the door off to change it? There are no obvious connectors or screws, though I can see a plastic ‘something’ on each side. Do I just pull up or down, or is there a magic widget to twiddle somewhere?
It’s marked 8545 600 15810; Ser: 33 0234 001434 if that’s any use..
look at the inner door when it is open, you will see four screws on each side of the door. Loosen the 2nd and 4th screw up from the bottom and close the door, push the decor door down and pull out away from the appliance. refitting is easy once you see how it is attached.
