Prima LPR660 stuck, all lights on
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Prima LPR660 stuck, all lights on
  • #98345
    roni_48
    Model: Prima LPR660, integrated
    I recently got a new house that came with this dishwasher. I run it once and seems doing the job. But now whenever I switch it on it is stuck. All the lights are on and it does not respond to any button.
    I disassemble the main door and disconnect and connect the panel connector and it get back and working again. But after, I run any program (without switch it off because it get stuck whenever I do so), it seems to work at first but after a long while it stops and beep twice (not sure if the program has finished). When I open the door, all lights are on again and the machine is stuck again.
    Is there something I can check or I am missing? Because the dishwasher came with the house I don’t know how old it is and maybe it is not worth to spend any money on it.
    Thanks for the help!
    #472001
    has your unit got a digital display and if yes do any error codes show ?
    roni_48
    No screen. Just the icons to select programs.
    #472003
    so when it fails are the lights just on, All of them
    or
    do some flash. if yes count the flashes and see if there is a sequence
    roni_48
    The lights are just on, all of them. It is like it stuck.
    #472005
    it sounds like a board fault
    you have no fault codes so its like the board just hangs up
    does it do it about 10 mins in or does it vary ?
    roni_48
    Never chrone it, but it seems it finish or almost finish at least. It always sounds similar.
    #472007
    roni_48
    I have decide to get rid of it as It doesn’t seems worth to pay for fix it.
