Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Prima LPR9022 Randomly Shuts Off and Starts Up Again
- This topic has 1 reply, 2 voices, and was last updated 6 years, 9 months ago by
yucca.
June 24, 2019 at 2:32 pm #96050
yucca
ParticipantHello
I have a Prima LPR 9022 Integrated Oven – I believe this comes under the Indesit/Hotpoint/Whirlpool group.
Recently, it has started behaving oddly. There are three control knobs on the front: function (LHS), timer (centre), temperature (RHS).
The function knob offers 4 functions which are (clockwise):
1) light
2) defrost (just the fans turn on)
3) fan oven
4) grillWhen function 3 is selected, the central fan comes on, the element heats up, the oven light comes on and the thermostat light comes on. However, every now and then the entire oven shuts down – no fan, heat, no lights. This appears to happen randomly. After a period of time, the oven starts up again.
I have exposed the wiring and nothing looks untoward. I have tugged at the various spade connections but they don’t trigger the shutdown. When it has shut down, I’ve attempted to work out where the power break is (using a multimeter), but just as I get round to checking, the damn thing starts again. It does not shutdown long enough for me to make any meaningful diagnosis – and as it appears to happen randomly, I don’t know when I can check.
I had a look at the control knob and I thought some of the copper prongs weren’t making contact as well as they should be so just bent them a little more to ensure contact when the knob rotates. That has not made much difference. Tugging at the wires seems to rule out loose connections.
I have got a copy of the wiring diagram (page 6 in http://www.prima-appliances.uk/pdf/m…lt-in-oven.pdf) and can see it uses
1) a thermolimiter for the cooling fan
2) an A class thermolimiter
3) a thermofuseThe only thing I can see which might control all of the impacted components is item #3 i.e. the thermofuse however I didn’t think that was an automatic resetable switch? And if that was tripping presumably that would indicate a failure elsewhere? Tthe thermolimiters seem to only control the cooling fan.
Any ideas?
Thanks in advance.
June 24, 2019 at 5:03 pm #462209electrofix
Moderatorsounds like the cooling fan (not the one inside the oven) is not working and the overheat thermostat is doing its job
