Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › prima/whirlpool dishwasher no heat!
- This topic has 7 replies, 4 voices, and was last updated 19 years, 4 months ago by
bzz67.
December 1, 2006 at 2:25 pm #23024
bzz67
Participantlpr600,machine runs through the whole cycle but no heat.no power to heater,heater checks out ok,pressure switch operates,thermistor changes resistance when cooled or heated,no breaks in wiring,changed module & still no heat.now i am stuck.any ideas!
simple enough circuit but i cant work this one out. (its been one of those weeks.)December 11, 2006 at 7:06 pm #196816maltheviking
ParticipantRe: prima/whirlpool dishwasher no heat!
I have had one of these today with the same fault, I was going to order a new user board(pcb) but after reading your diagnostics I am not so sure. 😕
This is a job for those Wpool. experts out there if you can help please :rolls:
Last week I had another Prima, faulty motor as usual but it had shorted and took out the user board 😥 15 months old ❗ Don’t you just love the quality 😥 sent the guy back to the retailer to complain about it, fit for purpose,
December 11, 2006 at 7:19 pm #196817DentedPorsche
Normally, if it completes the cycle with no errors it’s a software problem on the module. Changing the module would normally cure it. (Whirlpool engineer would rewrite software to module).
However, as you’ve already changed the module to no avail it really only leaves the NTC or wiring at fault.
To test the heater and wiring, disconnect at the module and test from there. You’ll test the wiring, TOC and heater in one.
Try running the diagnostic program and see if it throws up an error.Brian
December 11, 2006 at 7:32 pm #196818maltheviking
DentedPorsche wrote:Normally, if it completes the cycle with no errors it’s a software problem on the module. Changing the module would normally cure it. (Whirlpool engineer would rewrite software to module).
Hi Brian
Yep done all the tests from the module, heater has circuit, NTC had a circuit, although it measured 76kohm,cold, I am not sure if this is normal or not 😕 Test prog. shows nothing, completes cycle same as on a wash prog.December 11, 2006 at 7:58 pm #196819DentedPorsche
Ntc reading seems a bit high. Mind you, depends on the temperature.
At 20 deg 58.1 kohm
25 – 47.1
30 – 38.2
40 – 25.4
50 – 17.2
60 – 11.8
70 – 8.3
80 – 6
85 – 4
BrianDecember 11, 2006 at 8:42 pm #196820maltheviking
DentedPorsche wrote:Ntc reading seems a bit high. Mind you, depends on the temperature.
At 20 deg 58.1 kohm
25 – 47.1
30 – 38.2
40 – 25.4
50 – 17.2
60 – 11.8
70 – 8.3
80 – 6
85 – 4
BrianWater temp at tap. .is about 10c which by my calculation would give a reading about 90k, this looks ok 76k would be around 15c which is what it may have risen to after five minutes running when I tested it. 😕
Life was sweeter when we had timers and not all these micro processors :rolls:
December 11, 2006 at 11:17 pm #196821Marty-K
I`ve had two of these machines with the same symptoms as you described and on both occasions the NTC was the culprit. Part No. 481228268035. About 20 quid I think.
Marty
December 12, 2006 at 9:03 am #196822maltheviking
Thanks All
I will give the NTC a go and see what happens, watch this space 😉 -
