Prima Whirlpool LPR600
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Prima Whirlpool LPR600
  • #36162
    maersk
    😀 Hope someone can help.
    The machine has gone native. Pumps a bit, takes in water, swirls it about a bit then beeps at me. The machine then stops about a minute later.
    The programme has returned to ‘rinse’.
    Reset does nothing. There are 7 flashes in sequence on the ‘start’ button.
    The number on the door is 8545 600 15860.
    Is this terminal, or is it easily fixed?
    Thanks in advance
    #249818
    Re: Prima Whirlpool LPR600
    Flow Meter problems.
    maersk
    Thank you for your prompt reply.
    How do I access the flow meter to
    A) clean it and
    B) check connections
    #249820
    Remove left hand side panel. A nip of the connector block will often do the trick.
    Power off first.
    maersk
    Thanks, thats left as you look at it from the front fitted, yes?
    Sods law dictates that is fully integrated!!!!
    #249822
    maersk wrote:Thanks, thats left as you look at it from the front fitted, yes?
    Correct.
    maersk wrote:Sods law dictates that is fully integrated!!!!
    Thems the breaks…..
    maersk
    😆 This is one of the most helpful forums I have ever joined! Thanks Penguin.
    As I can’t find the ‘build-in’ instructions, can I just screw the feet in to lower its height and slide it out or will it be fixed to something?
    The worktop is granite so it can’t be fixed to that.
    How do you get the door off? 😕
    #249824
    Decor door removal – open door, slacken screws 2+4 by two turns – panel should slide down for removal.
    Fixing – there should be some sort of angle bracket in the top corners, allowing it to be screwed to either the work surface (obviously not) or the adjoining casings.
    If the floor is recessed, you will have to raise the feet. Be careful moving it, the long legs are a bit “bendy”.
    Enjoy………
    maersk
    😀 Better than a ‘phone call!
    Are the angle brackets obvious? i can’t see any thing
    #249826
    maersk wrote:😀 Better than a ‘phone call!
    Steady – this what I do for a living….. I’d have been and gone by now 😀 .
    maersk wrote:Are the angle brackets obvious? i can’t see any thing
    If you can’t see them, the machine may not be secured at the top. so see if it moves.
    maersk
    You sir, are a gentleman
