Privileg 1105 washer
  • #20515
    FLORIN
    First I put it on spining only.The motor start to work but only for few seconds, then stops, and the timer still work untill the end of the program.Also on any other washing programs the motor remain stoped.
    I check – the motor: it was ok.
    – the door lock: it was ok.
    – the timer (desansambled): it was ok.
    – the continuity between: timer – module pcb, module pcb – motor,
    it was ok also.
    – pressure switches: ok.
    In the end, I saw that the TDA1085C microcontroller was not receiving enough power in order to do his job, because one electrolytic capacitor of 470uF/25vdc just died.I replace the dead one with an 470uF on 35vdc.
    Somebody is happy now and somebody else keep ask himself how much can charge his client for one capacitor replaced in two minutes… 🙁
    All the best to every one,
    Florin
    #187320
    Re: Privileg 1105 washer
    One hour labour, plus parts 😀 .
    Who makes “Privileg” then?
    FLORIN
    Thanks Chris. 😀
    Endeed, lot of work in Privileg`s machines, but not often like in Indesit stuff…
    Cheers,
    Florin
