i bought a pro action model number A105qw (stupidly maybe) about 2/3 years ago. the last couple of months the spindle at the back that holds the belt on keeps coming loose during each wash, i have had someone out to sort it 3 times now and it just keeps doing it, i cant afford to keep paying someone to come fix it, is there a way to fix it permanently please.
Check that the alloy drum pulley centre hole only is worn-soft metal. Check the steel spindle flats it might be ok and only the pulley is zapped. You`ll have problems getting a pulley under the Pro Action label but might have better luck under the Bush label as both are Vestel made contraptions. Try Partmaster site and type in Bush and see if one of their pulleys match what you have. This may work for you and save the machine.
