i have a pro action a105q recently just stopped working , according to manuel fault code ‘start/pause’ button flashing states that door is not closed prperly ! As far as i can tell there is no problem with the latch and the door does appear to close properly so what else could the problem be ans is there anything i can do to fix this myself ?
POSSIBLY the door lock. You`ll have a problem getting this part under the Pro-Action label but physically have a look a Partmaster site but under Bush. You might also get the same part but cheaper under the Curry`s Essential label- you just have to look.
