Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › pro action bolts found under machine
- This topic has 12 replies, 4 voices, and was last updated 11 years, 10 months ago by
lacunningham.
May 25, 2014 at 10:55 am #80801
lacunningham
ParticipantI really need some help my pro action washing machine is over year an a half old . I used it the other day as it came to the last spin it was making way too much noise emptyed it an noticed that the door wasnt closing properly an the seal inside the top part of the door were out of place. I then moved the machine out an found two bolts about inch an half with what i could only say was is a plastic cover/ dracket it had fitted into. I know that when purchased there are t travel bolts but they were removed an still have them. I would really like t know if i can fix it or if it could of been a manufacturing fault. Please help.
May 25, 2014 at 10:59 am #414370Jackal
Participantpro action bolts found under machine
Front lower counterweight has sheered off the tub. The unit is scrap as the cost of the parts will make it uneconomical to repair.
This fault is common when a unit has been used whilst under loaded.
Jackal
Sent from my iPhone using Tapatalk 2May 25, 2014 at 3:46 pm #414371lacunningham
ParticipantRe: pro action bolts found under machine
So u think that its cause of under weight is there anything that could of been caused due to manufacturing fault. Would appriciate your appinion
May 25, 2014 at 5:21 pm #414372Martin
lacunningham wrote:could of been caused due to manufacturing fault.
It is always possible my friend but it is for YOU and you alone to prove it. But, hang on a mo, oh dear no, you can only do that in the first 6 months of purchase. 18 months old now and has reached its normal life expectancy anyway, so good luck with that !
May 25, 2014 at 6:14 pm #414373lacunningham
Thanks martin you have been great help many thanks.
May 25, 2014 at 6:31 pm #414374Martin
lacunningham wrote:Thanks martin you have been great help many thanks.
Are you serious? I told it to you like it is but I figured you would be less than pleased at my forthright reply. Honest and upfront all the while but some folks are unsettled by such.
But, I’m pleased to be of help. 😀
May 28, 2014 at 4:41 am #414375lacunningham
Asking if the counter weight bolt has snapped off the drum where can i get a replacement (think it would have to be the drum) an can i fix it.
May 28, 2014 at 8:15 am #414376iadom
ModeratorRe: pro action bolts found under machine
Jackal wrote: The unit is scrap as the cost of the parts will make it uneconomical to repair.
The answer has already been given, 😉May 28, 2014 at 10:31 am #414377Jackal
I can price it for you to be upset at but I will need the full model and serial number to ensure I look up the correct parts fitted to your unit.
Jackal
May 29, 2014 at 7:59 pm #414378lacunningham
Where would i find the no please any help as really good runner till it fell t pieces lol
May 29, 2014 at 8:06 pm #414379Jackal
Open the door and it will be on the sticker at the top of the chassis.
It will be the really long number
Jackal
Sent from my iPhone using Tapatalk 2May 29, 2014 at 9:22 pm #414380lacunningham
00627088002201900174
May 30, 2014 at 2:33 pm #414381Jackal
So you have model A105QS purchased from Argos which is the basic 1000rpm spin 5kilo machine they had on offer
Assuming you need just the following and that the inner drum etc. are all good then the spares only are £171.25 plus VAT. Shipping would be on top of this so total price would be around £210 ish to supply the parts only.
Tub front half
Tub rear half
Tub sealYou can currently purchase the latest variant from Argos today for £169.99 including VAT which will give you the same sized machine but with a 1200rpm spin capability a 6kilo Max load ability.
It’s a no brainer to me!
Regards
Jackal
Sent from my iPhone using Tapatalk 2 -
