problem with a indesit d41
Home Forums Public Support Forums Help And Support Dishwasher Help Forum problem with a indesit d41
  • #45066
    redscratch
    hi would like some advise on my dishwasher have a problem with the dispensor the door wouldnt open which was leaving the tablet inside i brought a new one but now the solinod on the back of the dispensor is constantly working which is making a loud noise all i have to do is to turn the dishwasher on and the solinod jumps into action my mate checked with his meter and there is power going to it.could anyone point me in the direction to fixing as im very lost all i done is replaced a part 😥
    Many thanks
    #283505
    Specialist01269
    Re: problem with a indesit d41
    Did you replace the dispenser complete with solenoid? it sounds from your description that the original solenoid was faulty, possibly due to being powered constantly.
    If this is the case, afraid it’s time for an Engineer to check the machine, unfortunately the Electronics on Indesit machines are not the best.
    PLEASE REMEMBER POWER OFF & PLUG OUT BEFORE OPENING.
    i.e YOU SHOULD NOT BE LIVE TESTING. 😯 😯
    For an Engineer in your area please see the repairs@ link.
    #283506
    redscratch
    yes i replaced dispenser complete with solenoid it is very strange as the old one never had that noise it just never opened the flap for the deturgent to be released ❗
    #283507
    Specialist01269
    The reason for it not having the noise was probably that the solenoid coil was open circuit & that’s why it wouldn’t open the door.
    #283508
    redscratch
    so could this be a problem with mainboard as its getting a constant feed to the solenoid which a solenoid dont need am i right in saying that?
    #283509
    Specialist01269
    Could well be a problem with the Electronics, the solenoid should only be powered during the part of the cycle where the dispenser should open.
    If it’s powered constantly then it will eventually burn out causing the problem you had originally.
    Time to call an Engineer Methinks.
    Andy.
    #283510
    redscratch
    many thanks for your help
    #283511
    Specialist01269
    No probs mate, sorry we couldn’t help you fix it.
    Andy. 8)
