Hello,
I have a NEFF Double Oven. The Timer has stopped working. Hello,
I think the Model Number is U1442N0GB/03
or FD8605
Normally when I turn the timer on the procedure is to:
(1) Turn the relevant oven on
(2) Set the temp required
(3) Set the Timer
When the Timer kicks in in turns the oven off till the appropriate time.
That suggests to me that the power for the Oven Elements pass through the timer in some way presumably via a Relay.
At the moment turning the timer on has no effect.
I am wondering is there a fuse or something protecting this (apparently) electronic timer?
Also I bought a NEFF Timer a while ago for a previous Oven. It does not fit this one but I wonder if there is a specific part (Relay) at may be common.
